April 20, 20205 yr Wooden front door on my house is fine. However Mom sold her house when she moved into retirment community and new owner is pretty much renovating everything so her old front door is now in my garage. It's about 60 years old and 200 pounds of old oak. She paid several hundred 30 years ago and then had it custom made so no matter what I have - it's an upgrade and it keeps it in the family. Problem is the height. My current one is 80 and this one is 79.25. How much of an issue am I getting in here. I have a general contractor doing some other work and I hope we can find a way to make it fit for obvious reasons. Is it easier to just raise the entrance threshold or should I try to lower the top threshold. Or just screw it and build a whole new frame?
April 20, 20205 yr 1 minute ago, AUinHsv said: Wooden front door on my house is fine. However Mom sold her house when she moved into retirment community and new owner is pretty much renovating everything so her old front door is now in my garage. It's about 60 years old and 200 pounds of old oak. She paid several hundred 30 years ago and then had it custom made so no matter what I have - it's an upgrade and it keeps it in the family. Problem is the height. My current one is 80 and this one is 79.25. How much of an issue am I getting in here. I have a general contractor doing some other work and I hope we can find a way to make it fit for obvious reasons. Is it easier to just raise the entrance threshold or should I try to lower the top threshold. Or just screw it and build a whole new frame? Can you not have 3/4" cut from the head or sill of the oak door ?
April 20, 20205 yr 2 minutes ago, Onboard 2.0 said: Can you not have 3/4" cut from the head or sill of the oak door ? I read it as the repurposed door is smaller than existing. OP> Submit a RFI to Onboard.
April 20, 20205 yr 1 minute ago, Upgrayedd said: I read it as the repurposed door is smaller than existing. OP> Submit a RFI to Onboard. D'oh, yes smaller..... I hate math !!! I'd try to lower the head and casing, but a raised threshold would be probably easier.
April 20, 20205 yr I read it as the repurposed door is smaller than existing. OP> Submit a RFI to Onboard.Does he need an RFI or a change order?
April 20, 20205 yr 1 minute ago, EE2B said: Does he need an RFI or a change order? A math lesson.....then an RFI, then a change order.....
April 20, 20205 yr Could you glue/nail/screw a 3/4 inch strip of oak to the bottom? Might have to refinish the entire thing to make it match.
April 20, 20205 yr Author interesting idea. May have to refinish it anyhow. The contractor who took it off Mom's house stored it in garage and somehow the shellac varnish coat started pealing. No clue why because it is marine varnish but I still may have to strip and stain again.
April 20, 20205 yr 58 minutes ago, dingleberryswitzer said: Could you glue/nail/screw a 3/4 inch strip of oak to the bottom? Might have to refinish the entire thing to make it match. That's an option if he needs to refinish the door for sure. Lowes carries small pieces of hobby sized, oak that would work pretty easily.
April 20, 20205 yr Just now, Gil Bang said: a sweep would cover most, if not all, of that strip. Ohh that's a crime......
April 20, 20205 yr 13 minutes ago, Gil Bang said: a sweep would cover most, if not all, of that strip. 13 minutes ago, Onboard 2.0 said: Ohh that's a crime...... Do an auto bottom then.
April 20, 20205 yr Can you send pics of the interior and exterior of the existing door? You may want to consider that you'll probably have to re-mortise for hinges on the existing jamb, so replacing trim and lowering the header with a strip of 1X material would be pretty simple as long as your interior and exterior conditions don't cause that to open a can of worms.
April 21, 20205 yr I think the easiest solution would be to burn the whole house down and build a new one designed around this door size.
April 21, 20205 yr If the “new” door hinge mortises match up with your current door frame, then cut .375” off the top and .375” off the bottom.
April 21, 20205 yr Just now, Armybrat said: If the “new” door hinge mortises match up with your current door frame, then cut .375” off the top and .375” off the bottom. The door is too small to begin with. You and Onboard should hang out.
April 22, 20205 yr 6 hours ago, Whitman said: I think the easiest solution would be to burn the whole house down and build a new one designed around this door size. tamu approved?
April 22, 20205 yr This has happened to me a few times, I find it you just flip it upside down it works perfectly
April 22, 20205 yr 12 minutes ago, Digdogger said: This has happened to me a few times, I find it you just flip it upside down it works perfectly Oh yeah I like that plan.
April 22, 20205 yr Oh yeah I like that plan.Too small door needs to be moved to snek thread.....for obvious reasons.
April 22, 20205 yr I've always heard that if it's too small then it's easier to put it in the back door
April 23, 20205 yr Perhaps you might find a subscription to Door Sizing Quarterly to be helpful in your journey. Sometimes the editorial slant is a little too progressive for my tastes, but their ongoing series "Using a Tape Measure" is always a quality resource.
April 23, 20205 yr 2 minutes ago, Prepuce of Doom said: Perhaps you might find a subscription to Door Sizing Quarterly to be helpful in your journey. Sometimes the editorial slant is a little too progressive for my tastes, but their ongoing series "Using a Tape Measure" is always a quality resource. Fucking arty rag..... Popular Doors for the win..... "measure once cut twice, anything worth doing, is worth doing twice", is my favorite monthly feature... that and the centerfold of course.
April 23, 20205 yr Disagree - some of the shit they advocate with hinges is downright criminal. But I'll acknowledge that the centerfolds usually give me wood.
April 23, 20205 yr 19 minutes ago, Prepuce of Doom said: Disagree - some of the shit they advocate with hinges is downright criminal. But I'll acknowledge that the centerfolds usually give me wood. Watch out, next month is keyless locks....
April 23, 20205 yr 28 minutes ago, Prepuce of Doom said: Perhaps you might find a subscription to Door Sizing Quarterly to be helpful in your journey. Sometimes the editorial slant is a little too progressive for my tastes, but their ongoing series "Using a Tape Measure" is always a quality resource. 23 minutes ago, Onboard 2.0 said: Fucking arty rag..... Popular Doors for the win..... "measure once cut twice, anything worth doing, is worth doing twice", is my favorite monthly feature... that and the centerfold of course. 16 minutes ago, Prepuce of Doom said: Disagree - some of the shit they advocate with hinges is downright criminal. But I'll acknowledge that the centerfolds usually give me wood. One of my tasks in my first job out of school was coordinating the install of over 1,500 door openings that some asshole believed was economical to issue independent POs/contracts to a hollow-metal door/frame supplier, a wood door supplier, a hardware supplier, and an installer. Drawn by an architect that subbed out the spec writing. There was not a day where I didn't have three or four hardware/door issues to chase down. Shudders.
April 23, 20205 yr Peepholes? Edited April 23, 20205 yr by Shoxthemonkey Tried to sneak it in before Upgreyed and lost
April 23, 20205 yr 2 minutes ago, Onboard 2.0 said: Watch out, next month is keyless locks.... I'll get my lube ready! (*powdered graphite FTW - WD40 is for posers and n00bs)
April 23, 20205 yr 3 minutes ago, Upgrayedd said: One of my tasks in my first job out of school was coordinating the install of over 1,500 door openings that some asshole believed was economical to issue independent POs/contracts to a hollow-metal door/frame supplier, a wood door supplier, a hardware supplier, and an installer. Drawn by an architect that subbed out the spec writing. There was not a day where I didn't have three or four hardware/door issues to chase down. Shudders. Holy shit.
April 23, 20205 yr 9 minutes ago, Shoxthemonkey said: Peepholes? Pro tip: make sure that the distance between the peephole and the mail slot corresponds to the distance between your eyes and your, ahem, "outgoing package" if you're into that sort of thing. Just make sure you don't live too close to a school, of course... Edited April 23, 20205 yr by Prepuce of Doom
April 23, 20205 yr 7 minutes ago, Prepuce of Doom said: Pro tip: make sure that the distance between the peephole and the mail slot corresponds to the distance between your eyes and your, ahem, "outgoing package" if you're into that sort of thing. Just make sure you don't live too close to a school, of course... 20 year subscriber to Door Peep and Perv right here ^^^^^
April 25, 20205 yr Go get a door stretcher at Home Depot, they are right next to the mattress scales. CHIEF
April 26, 20205 yr Just change out the header for a thicker one or add a one-by board to the current header, wood filler to the seams, sand, and repaint the frame to blend it in.
May 29, 20205 yr Add a thicker threshold...everything else stays the same. You mess with the header, you mess with the casing...
June 3, 20205 yr Author Until we get it mounted - no decisions. Right now I am leaning towards a strip on the top or bottom to fill gap. Having door stripped to re-stain so this makes some sense
